LightArms - A Budget Laser Tag System
A relatively simple, inexpensive laser tag system with customizable game modes
Laser tag systems with sensor vests and multiple game modes are typically very expensive. Since I like digital electronics projects, and I have much more time on my hands than money, I decided to design and build a laser tag system with multiple game modes that I can afford to build.
This project was somewhat influenced by the LZRTag project, but is very different and should cost *much* less to build.
The general design is to have each player have 1 or 2 guns, connected to a vest, with a "mother beacon" to setup the game and report players' scores.
Sensor:
  • uses a single Vishay TSOP4838 IR receiver as main component, with a PNP transistor to buffer the signal
  • uses 2 RGB LEDs as hit indicators
  • casing: TBD (probably mostly 3D printed)
  • all sensors are connected via a 6P ribbon cable (1.27mm pitch) with 3x2 2.54mm IDC connectors
  • component cost: <$1 per sensor (from LCSC)
Guns "Genesis" and "Magnum":
  • runs directly from 2x AA batteries
  • input: trigger, team select, 2x weapon select (backward and forward)
  • 3D printed casing
  • uses STM32F0 (STM32F030C8T6) microcontroller
  • uses Vishay TSOP4838 IR receiver (same as on sensor) for hit detection as well as communication with mother beacon
  • uses IR333-A (R) IR LED with lens for shooting as well as communication with mother beacon
  • uses generic red laser diode for laser dot
  • uses 8-Ohm speaker for audio output (used to indicate when hit and when game begins and ends)
  • uses standard SPI flash memory module to store sound data
  • no display (displays can be way more awkward than you might think)
  • component cost: probably $2 - $3 per gun (from LCSC)
Current status:
Guns:
  • Genesis (first gun design; basic pistol): PCB designed; casing design still needs a lot of the dimensions to be verified/fixed
  • Magnum (basic pistol; essentially an improved version of Genesis): electrically very similar to Genesis; casing design started; PCB layout depends on casing design
Mother Beacon: PCB partially designed; casing design still in concept stage
Vest: sensor PCB and casing designed and assembled; needs some sort of vest to be attached to
If anyone wants to help me, please message me! I would greatly appreciate it.
In particular, I could really use some help with the Magnum gun's physical design.
gun-genesis.zip
KiCad files for the first gun PCB (codenamed "Genesis")
Zip Archive - 177.56 kB - 04/09/2020 at 02:32
Download
sensor.zip
KiCad files for the sensor PCB
Zip Archive - 35.06 kB - 04/06/2020 at 04:07
Download
  • Status Update #4
    Ben Larson05/25/2020 at 20:47 0 comments
    I was able to get the IR communication all working, so now I'm really close to having basic laser tag functionality. It turned out that my big problem was that I had fried the infrared receiver I was trying to use, and once I replaced that, I was quickly able to get it to work.
    As for the sound, I've tried writing a simple program to emulate the I2S-like LSBJ protocol used by the PT8211 DAC, but I still can't get any sound except for a whine from the electrical noise. At this point, I've basically given up on audio for the Genesis gun, and I'll use an MCU with I2S support for the Magnum gun.
  • Status Update #3
    Ben Larson05/23/2020 at 23:19 0 comments
    Well, my PT8211 DAC chips finally arrived, so I've started testing the sound system. Unfortunately, the I2S protocol used to communicate with the DAC is more awkward to implement than I thought, so right now the only sound I'm getting is from electrical noise. The PWM signal used to drive the LEDs creates a fair amount of noise, so I should probably decrease the amplification on the Magnum board. I just wish I knew how much to decrease it by.
    On the firing side, I have gotten the gun to output a 38kHz IR signal, which I can detect using an IR receiver and an oscilloscope. I haven't been able to detect the signal yet from the MCU, but that seems to be a configuration issue. The STM32 timers are incredibly powerful, but also rather confusing.
    If anyone reading this happens to be familiar with implementing I2S using SPI or using input capture on an STM32 MCU, please message me.
  • Status Update #2
    Ben Larson05/11/2020 at 19:51 0 comments
    The boards and most of the components for the "Genesis" gun have arrived. I've tested what I easily can, with some eventual success. I got the soldering wrong multiple times, which resulted in a lot of frustration. Now, I've been able to confirm that at least some of the hardware works, but I haven't gotten the chips necessary for testing the gun's audio system, which is what I've been least confident about anyway.
    My gun casing design is close to working, but it's a lot more awkward to assemble than I expected. In particular, the buttons aren't on the PCB, so I'm connecting them with wires, which is a pain. With that, along with other issues, I'm inclined to verify the sound system, then work on the "Magnum" gun design. I've lost most of my patience for gluing in buttons and switches, so I'll try to design my new gun to have everything except the trigger and the speaker on the PCB. I need 2 guns to adequately test the IR optics, so I'm really hoping everything goes well. Fortunately, I can remove the lens and/or replace the resistor for the IR LED if I get too much ricochet. I'm confident that my IR signal won't be too weak, at least indoors.
    For the "Magnum" gun, I need to upgrade my 3D printer to use a dual extruder, so I can make the supports more easily removable.
    I have less energy and free time than I used to, and my mental health is pretty bad, so I won't be moving this project forward all that quickly during the next few months, but I'm not just putting this project on the shelf and leaving it there either.
  • Status Update #1
    Ben Larson04/22/2020 at 03:12 0 comments
    The sensor and "Genesis" gun PCBs and components have been ordered and will eventually arrive sometime, probably early May.
    The casing design for the "Genesis" gun is partially complete, to the point that I need some of the components to figure out proper dimensions so everything can fit together nicely.
    I've written most of the low-level code for the firmware, but I need the actual hardware to test it. Who knows how many bugs there will be?
    I've started on the "mother beacon" (does anyone have a better name for it?) PCB design, which incorporates several parts of the gun PCB design, so I'll want to verify those parts work well before getting too far. Fortunately, I shouldn't have much trouble getting one of the guns to function as a very basic "mother beacon" until I have the proper PCB and code.
    I haven't really designed the sensor casing yet, so I'll be working on that soon probably.
View all 4 project logs
gordon wrote 04/09/2020 at 01:06 point
built a small proof of concept just for myself a while back, 2 units total. most info learnt from: https://lasersandlogic.weebly.com/ might wanna check that out.
Ben Larson wrote 04/09/2020 at 02:54 point
Cool! It seems like everyone else is using various types of radio communication, while I'm doing everything with IR.
Can you tell me how much current your IR LED used in your setup? And did you use any lenses? I want to have a better idea of how much power is actually needed, and whether I'll be able to use diffused sensor casings in my system, or whether I'll need to stick with clear like everyone else.
