• Pinout
    Saabman04/23/2020 at 12:41 0 comments
    After scouring through the SAAB Workshop Information System I finally found the wiring diagram for the Windows. Funnily enough not located in the wiring diagram section but under
    • Body
      • Glass, windows and mirrors
        • Electric window lifts
    1. NC
    2. Rear Right 1
    3. NC
    4. Illumination in
    5. Rear Right 2
    6. Front Right 1
    7. Front Right 2
    8. Ground
    9. Rear Window lock (12V active 0V locked)
    10. NC
    11. 12V in
    12. 12V in
    13. NC
    14. NC
    15. NC
    16. Rear Left 1
    17. Rear Left 2
    18. Front Right 2
    19. Front Right 1
  • What does it do?
    Saabman04/06/2020 at 12:11 0 comments
    The SAAB 9-5 windows are solely under the control of the window control module independently of the "computers" in the car. It is not much more than 5 mechanical switches a relay and some minor analog circuitry.
    Functions:
    1. windows up and down via switches
    2. over current cut out
    3. press down for a short period and the window goes all the way down.(front windows only)
    4. lock out switch to disable rear windows so the kids cant play with them.
