Log#21: First details of the new "extended" long instruction
A project log for YASEP News archives
A backup of the blog before the host erases it. A good opportunity to review the development, twists and turns of this ISA !
yann-guidon-ygdesYann Guidon / YGDES 04/08/2020 at 02:230 Comments
By whygee on Saturday 4 April 2009, 16:31 - Architecture
A precedent post has summarised the available "instruction forms", with or without immediate field (4 or 16-bits), with 2, 3 or 4 register addresses. Here we look at the "long form" (32-bit) using the "extended" fields that add 2 register addresses, conditional (speculative) execution and pointer updates.
Let's now examine the structure of the 16 bits that are added to the basic instruction word :
These fields are mostly orthogonal and can work in almost any combination. One can auto-update 2 registers (whether they are normal or belong to a memory access register pair), perform a 3-address operation and enable write-back depending on 97 conditions. It also preserves the availability of short immediate values, which further reduces code size. However it can increase the core's complexity.
One unexpected bonus is that this new architecture iteration is more compiler-friendly. At least, it's much less awkward or embarrassing.
One bit could have been saved : the imm4 flag could be merged in the auto-update field for a source register. However this increases the logic overhead and prevents simultaneous use of auto-update AND imm4.
Stay tuned...
20200408:
the auto-update field has been updated much later... But at least this log got somewhere great.
