UVC banana and rubber test
A project log for naminukas
Pneumatic walking, driving, wall climbing and tool using robot
mykolas-juraitisMykolas Juraitis 07/13/2020 at 08:201 Comment
Last week I have added a small UVA+UVC LED to naminukas. While I emphasized in the video that disinfecting function is just a proof of concept and in the final product more powerful ultraviolet lamps should be used, I got a few comments saying that a lot of UVC LEDs are fake and I should do a banana test. Banana skin is supposed to get darker under UVC light. While testing with bananas I also noticed that nitrile rubber tire near LED got cracked:
Hopefully that proves that from sufficiently short distance my LED would kill bacteria too. I will need to replace rubber tire with silicone which is UV resistant.
On the next day, an area surrounding darkened spot got darker too:
UVC irradiated bananaI wonder if it is because of stray UV light or the original spot caused surrounding area to ripen faster. I you know more about UV exposure effects please let me know in the comments.
John Loeffler wrote 07/13/2020 at 18:36 point
I would Try green bananas at a distance far enough away that heating effect would not work.  Making it would also give you a better contrast see this video (https://www.youtube.com/watch?v=7FbDVX7wvgI)
