Robot on a swing
A project log for naminukas
Pneumatic walking, driving, wall climbing and tool using robot
mykolas-juraitisMykolas Juraitis 06/25/2020 at 14:062 Comments
This week I was experimenting with unstable robot behaviour, namely pumping a swing:
I tried various strategies like periodically turning robot on one leg, moving leg up an down aligned with swing seat or perpendicular to it. Apparently pumping a swing is quite a complicated process. In practice it is possible to achieve some results with a simple periodic motion. In the video above robot starts moving up and down with a period of 0.6s and decreases period by 2ms every swing. Motor acceleration speed also affects swing pumping so it had to be tuned.
Mike Szczys wrote 06/25/2020 at 15:02 point
That's interesting that you decrease the period with each pump.  I think you did at least as well as the one's using machine learning.
https://www.youtube.com/watch?v=ke6xKwXwFZU
Mykolas Juraitis wrote 06/25/2020 at 15:13 point
Indeed it is not obvious why decreasing period worked better than increasing in my case as period of swinging increases with larger amplitude. Maybe I was just lucky to guess some resonance causing numbers.
I did watch video you posted before starting my project to get some hints. There are surprisingly few videos of swinging robots.
I might try more scientific approach to swing higher in the future but it might require building a more sturdy swing.
