K3
Latching Solenoid or Relay driver
Three half bridge and a common half bridge that can be used to discharge a (9V/12V/24V) capacitively stored charge into a latching Solenoid or Relay coil.
A current limited (300mA pk) boost converter on board can be enabled to build up the storage capacitor from the input supply. The bridge driver provides a quick current pulse, which creates a Laplace force that throws the solenoid into a latched position.
View all 4 project logs
