partLabels.pngShows the bender ready to bend a tab. The bender's parts are labelled.Portable Network Graphics (PNG) - 924.61 kB - 04/07/2020 at 20:46 |
notFlat.pngThe shape of the hinge prevents the workpiece from lying flat. Because of that, and to increase rigidity, a top plate should be added.Portable Network Graphics (PNG) - 463.30 kB - 04/07/2020 at 20:46 |
so.pngShows adjacent bends offset so a rivet tab can slide in behind a side.Portable Network Graphics (PNG) - 312.98 kB - 04/07/2020 at 20:46 |
alClose.jpgA close up of a piece of aluminum being bent. Note that it bends closely around the front profile of the finger.JPEG Image - 121.77 kB - 04/07/2020 at 20:46 |
ssClose.jpgA close up of a piece of stainless steel being bent. Because of its stiffness, it makes an air bend rather than conforming to the shape of the finger.JPEG Image - 113.47 kB - 04/07/2020 at 20:46 |
clamping.pngShows a nut and bolt used for pulling the hinge leaves together to make a bend. This means that the workpiece can be bent completely around the finger to form a tube.Portable Network Graphics (PNG) - 17.86 kB - 04/07/2020 at 20:46 |
sv.pngThis shows how machine screws hold everything together and align the bends.Portable Network Graphics (PNG) - 28.87 kB - 04/07/2020 at 20:46 |
