Alpha release 1.8.0-alpha.6
A project log for zeptoforth
A full-featured Forth-based RTOS for ARM Cortex-M
travis-bemannTravis Bemann 09/10/2024 at 03:470 Comments
This alpha release introduces PSRAM support for the RP2350 on boards that have PSRAM. Note that the user must manually enable PSRAM support, as it requires supplying the identity of the QMI CS1n GPIO to use.
