Bug-fix release 1.12.0.1
A project log for zeptoforth
A full-featured Forth-based RTOS for ARM Cortex-M
travis-bemannTravis Bemann 03/21/2025 at 23:570 Comments
This bug-fix release turns off debug mode for zeptoIP by default, which had been set to on by mistake. No binaries have changed, even though their filenames have changed to reflect the version number change, so if you have already downloaded zeptoforth 1.12.0 you do not need to download this release unless you plan on using zeptoIP.
