Currently this project is complete. It was supposed to be a quick build to fulfill a particular requirement with the components that I had at hand. The current generation/build has met these requirements however it is far from polished, and I may, in the future revisit this project. There are a few things that I would change or improve on if I were to build this again, particularly with the light control. Ideally the use of three potentiometers to control each colour channel individually would be better.
Inderpreet Singh
Ben Lim
Garrett Brainard
Cordova Labs
