A new 'FPC Stick' from Adafruit arrived in the post recently, and I set to work attempting to get the ICM2 display to operate through it.
The end goal here is to be able to use two of these FPC connectors on a custom PCB (and possibly two more, to intercept the 30-pin FPC from the buttons/switches on the ICM unit) in a kind of "Man-In-The-Middle" arrangement. This will allow for very easy Stock / Custom switching, if desired!
Here's a close up shot of the crappy soldering I did.
No project would be complete without a bodge wire or two, at least, in my experience.
Here's a photo of the whole setup in breadboard form at the moment.
Also, yes, I mistakenly wrote BUILT from Jets, instead of BORN from Jets. You've caught me, I'm a fake fan. I'll turn in my keys immediately...
Leigh Oliver
Completely forgot to mention, the pin connections required for the FFC/FPC is available here:
https://github.com/leighleighleigh/SAAB_ICM2_LCD_RE/blob/master/KICAD_SAAB_ICM_2_Display/SAAB_ICM_2_Schematic.pdf
