This repository of conveyor_system provides all parts you need to build the conveyor system. Delta-Robot One and also this system are mainly designed for students and makers with an educational thought. The Conveyor System for Delta-Robot One is designed as a kit. The pluggable mechanical solution make the assembly fast and easy. Like Delta-Robot One this system is basicly build of lasercutted and 3D-printed parts. An introduction at the containing wiki provides a description of all parts including production files, drawings and a list where you can get the parts. If all the parts are produced and/or delivered the assembly steps will be described at the wiki page. The last step decribes the usage of the system with Delta-Robot One.
Direct link -> >>>Conveyor System Wiki<<<
With the help of a community (this means you) it could be a world wide educational project. Working on this project is a lot of fun. Learning something about the different topics and share it with the world is realy great. Be part of it...
This video clip show a Delta-Robot One with long pillars found at hardware parts and the Conveyor System.
We used a system like this to grasp some chips at the image processing lab of our university. We detect the chips, the colour and the velocity. In the video above you can see a simple system with no image processing. The chip is only detected by a time of flight sensor. The motor of the conveyor system and the sensor are both connected to the robots interface. This shows the possibility to extend your robot. There are interfaces provided for Gripper/GND (ON/OFF), Motor/GND (PWM max. 4A), I2C Bus (SCL/SDA), Power/GND (5V/max. 4A)
Delta-Robot One
If you don't know Delta-Robot One check out:
Hackaday Delta-Robot One
GitHub repository how_to_build_your_robot
Mykolas Juraitis
Malte Ahlers
Swaleh Owais
Dejan
Thanks :) It would bei great If every classroom have 10 of this ;) Thanks for your ideas too, I will think about it and maybe start a project with a microscope in the future. In the moment i worked on a Raspberry Pi based image vision system for Delta-Robot One and the Conveyor System.
