One of the big problems I found in traditional irrigation systems through underground sprinklers is that once positioned, the sprinklers are not only difficult to adjust but any garden furniture placed later can stop them from working by hiding them.The consequence is that some areas are not watered or others are watered excessively.The solution is very simple ... AQABOT! A PAN / TILT system that simulates the human movement but better :)The first phase consists in programming the unit: through a joystick it is possible to direct the jet of water to the desired position and by means of a button to mark this position of interest. Iterating this simple procedure, this information is saved on an SD card going to compose a list of points of <a target="_blank" rel="noopener noreferrer" href="http://interest.In">interest.In</a> the following run mode AQABOT executes the program step by step going over the saved path.
Details
Files
AQABOT.apk
ALFA release of the APP for control AQABOT from mobile...
Managing a joystick, mechanical switch, cable connection starts to be noisy. So... why do not deploy an app for android in order to do the same op comfortably from the couch without connection. Further improvements in the circuit too on next days...
Dismissed Joystick... no more 3D printed part to manage.... led... switch... water isolation.
would be amazing! it could be an interesting development ... the detection of a position to hit .. maybe based on the analysis of a photograph taken by an ipcam present in the home lan.
You are right! :)
