SD-S260320-R230520-v3.zipThe content of the microSD for IOS S260320-R230520. Added the /teratem folder with files and instructions to setup an 8088 assembler automated toolchain. See ChangeLog.txt inside the SD image.Zip Archive - 2.63 MB - 06/19/2020 at 14:13 |
S260320-R230520_IOS_V20-MBC.zipThe sketch for the IOS (with the needed libraries). Unzip into a folder and open the .ino file (with Arduino IDE). IOS must be uploaded into the Atmega32A flash. Added CP/M-86 support. See the Changelog in the .ino file. The Serial port speed is 115200 bps (8N1).Zip Archive - 38.58 kB - 06/04/2020 at 17:53 |
S260320_R230520.ino.with_bootloader_atmega32_16000000L.hexThe sketch for the IOS in executable format (.HEX) with the bootloader. This executable file is intended for use with a programmer as the Atmel Ice or AVRISPmkII or others (Fuse bits: High Byte 0xD6, Low Byte 0xAF, Lock Byte 0xCF)x-hex - 57.84 kB - 06/04/2020 at 17:55 |
CPM-86 Personal Basic 1.1 Tutorial.pdfTutorial and manual for DRI Personal Basic v1.1 for CP/M-86. Please read it before to start using Personal Basic for CP/M-86.Adobe Portable Document Format - 2.79 MB - 06/04/2020 at 09:45 |
A250220 - SCH.pdfSchematic.Adobe Portable Document Format - 221.90 kB - 04/21/2020 at 11:27 |
A250220 - Gerber.zipPCB gerber files.Zip Archive - 481.69 kB - 04/21/2020 at 16:10 |
A250220 - Assembly guide.zipPCB Assembly guide.x-zip-compressed - 101.52 kB - 04/21/2020 at 11:27 |
A250220 - BOM v3.odsBOM file.spreadsheet - 14.97 kB - 04/10/2021 at 08:56 |
uPD70108H (V20HL).pdfV20HL (uPD70108H) Datasheet.Adobe Portable Document Format - 2.14 MB - 04/18/2020 at 09:10 |
80C88 Datasheet.pdf80C88 Datasheet.Adobe Portable Document Format - 1.72 MB - 04/23/2020 at 08:28 |
