Nuclear earrings
Glow in the dark ionizing radiation hazard symbol earrings
Ever since getting LIT (https://www.culturehustleusa.com/products/lit-the-worlds-glowiest-glow-pigment-100-pure-lit-powder-by-stuart-semple) I knew I will do these earrings.
Process:
1. Design hazard symbol model in OpenSCAD
2. 3d print
3. Cover printed symbol with thin layer of epoxy (basically paint with epoxy) in order to smooth out lines of 3d print
4. Make silicone mold out of that
5. Mix LIT into transparent epoxy and cast into the mold
6. Drill holes for hooks and screw them in
Lizette Jones wrote 03/30/2021 at 13:12 point
This looks amazing and I have made some designs like https://beenecklace.net/category/queen-bee/
Dan Maloney wrote 04/13/2020 at 21:05 point
Now if the earrings start glowing again after they've discharged, you know you're in trouble.
Ivan Bakhtin wrote 04/14/2020 at 07:43 point
True, either radiation, or, as LIT glows a bit when heated, terrible fever.
