Raspberry Pi 4B
A project log for ROVER-X
A STEM PROJECT
ameerAmeer 04/25/2020 at 16:530 Comments
I decided to use the newest Raspberry Pi model as of today; the RPi-4B.
It can be powered via the USB-C port, and it uses a Micro-HDMI to output display.  You will also need an 8GB Micro SD Card (or 16 or 32; I chose a 16GB), and an SD Card Sleeve for it.
https://www.raspberrypi.org/downloads/
Download The firmware Raspbian onto your PC, download Installer onto your PC as well, then run Installer and choose Raspbian as the firmware and the Micro SD Card as the place to install its image. Your SD card is ready to be placed into your RPi and you can now run your RPi as a small computer; connect a usb keyboard and a usb mouse and a screen to it, turn it on; the user interface looks like any Windows PC.
NOTE: If you buy a Pi4-B make sure you also buy or have:
HDMI- Micro-HDMI Chord
USB-C power & chord with 5 volts and 3.1 amps
Gen 10, micro SD card  & SD Sleeve
You will need a USB Keyboard and a USB Mouse later to use the Pi
