RCCClockBase.jpgWhy poplar? It carves so nicely. The most visible excavations are for the crystal, battery and holder, and the largest is for the power connector.JPEG Image - 132.45 kB - 04/17/2020 at 17:51 |
RCCC_FirstBase.jpgYou can see that the illuminated part of the resistor's bands is much narrower than the final base.JPEG Image - 196.03 kB - 04/17/2020 at 18:02 |
RCCClock.cI'm fairly certain that this is the code flashed in to the working RCCC. The Zilog development system was used for the build.x-csrc - 33.69 kB - 04/15/2020 at 15:26 |
RCCClock.tcwThe original TurboCAD 9.0 drawing.tcw - 77.00 kB - 04/15/2020 at 15:19 |
RCCClock.dwgUpon resurrecting my TurboCAD install, this is what it exported in AutoCAD's DWG format.DWG Drawing - 1.85 MB - 04/15/2020 at 15:16 |
RCCClock.dxfDoes anyone use DXF these days? If the global lockdown continues much longer, I'll hunt down some DXF tools and see what this file looks like.AutoCAD DXF - 5.94 MB - 04/15/2020 at 15:11 |
