Exoskeleton arm made of aluminum and steel cable
Hey! What is actuating the arm of the other end of the wire?
Hey Actuator similar to the one on the link
https://produto.mercadolivre.com.br/MLB-1294150282-kit-adaptador-para-maquina-de-vidro-eletrico-com-motor-_JM?quantity=1#reco_item_pos=0&reco_backend=machinalis-pads&reco_backend_type=low_level&reco_client=vip-pads-right&reco_id=e2a6f9db-609f-47c8-b6c9-f68cad244b01&is_advertising=true&ad_domain=VIPCORE_RIGHT&ad_position=1&ad_click_id=YjNkMWEzYjgtYjE4Yi00NDljLThmZjQtMmIzZGQ3MTdkYmMx
Gavin Martin
Mahesh Venkitachalam
Jordan Réjaud
wglasford
Yes, delete it Cancel
You are about to report the project "Exoskeleton", please tell us the reason.
