Introduction
The NEO430 is a TI msp430-native tiny microcontroller-like processor system. The system is highly configurable and provides of standard IO and peripheral components. If a certain module is not required at all it can be disabled and thus will not be synthesized. The project features Makefiles for Linux / Powershell / Windows' Linux Subsystem and provides driver libraries for all peripheral devices as well as example programs.
To get the complete information overload take a look at the NEO430 Datasheet.
Differences to the Original MSP430 Processor
The NEO430 provides full ISA-compatibility to the original msp430 CPU. However, there are some differences. Here are the most important ones:
- Completely different processor modules with different functionality
- Up to 48kB instruction memory and 12kB data memory
- NEO430 tool chain (makefiles, boot-code and linker script) required for application compilation
- No support of CPU's DADD operation
- Different numbers of instruction execution cycles
Processor Feature
- 16-bit open source soft-core microcontroller-like processor system
- Full support of the original MSP430 instruction set architecture (except for the DADD instruction)
- Code-efficient CISC-like instruction capabilities
- Tool chain based on free TI msp430-gcc compiler
- Application compilation scripts (makefiles) for Windows Powershell / Windows Subsystem for Linux / native Linux
- Completely described in behavioral, platform-independent VHDL (no macros, primitives, attributes, etc. used)
- Fully synchronous design, no latches, no gated clocks
- Very low resource requirements and high operating frequency
- Internal DMEM (RAM, for data) and IMEM (RAM or ROM, for code), configurable sizes
- Customizable processor hardware configuration:
- Optional multiplier/divider unit (MULDIV)
- Optional high-precision timer (TIMER)
- Optional universal asynchronous receiver and transmitter (UART)
- Optional serial peripheral interface (SPI), 8 or 16 bit tansfer data size, 6 dedicated CS lines
- Optional I2C-compatible two wire serial interface (TWI) supporting clock stretching
- Optional general purpose parallel IO port (GPIO), 16 inputs & 16 outputs, with pin-change interrupt and PWM option
- Optional 32-bit Wishbone bus interface adapter (WB32) - including bridges to Avalon (TM) bus and AXI4-Lite (TM)
- Optional watchdog timer (WDT)
- Optional cyclic redundancy check unit (CRC16/32)
- Optional custom functions unit (CFU) for user-defined processor extensions
- Optional 4 channel PWM controller with 4 or 8 bit resolution (PWM)
- Optional Galois Ring Oscillator (GARO) based true random number generator (TRNG) with de-biasing and internal post-processing
- Optional external interrupts controller with 8 independent channels (EXIRQ), can also be used for software-triggered interrupts (traps, breakpoints, etc.)
- Optional NCO-based programmable frequency generator with 3 independent channels (FREQ_GEN)
- Optional internal bootloader (2kB ROM) with serial user console and automatic boot from external SPI flash (like the FPGA configuration storage)
FPGA Implementation Results
The clock frequency has been constrained for the Xilinx and the Lattice implementation.
| Xilinx Artix-7 | Intel Cyclone IV | Lattice iCE40 UltraPlus | |
| Full setup: | 1036 LUTs, 1144 FFs, 2.5 BRAMS, 100MHz | 1869 LUTs, 1137 FFs, 65800 MEMbits,121 MHz | 3928 LUTs, 1923 FFs, 9 EBRs, 2 SPRAMs, 20.25 Mhz |
| Minimal setup (CPU + GPIO): | 573 LUTs, 266 FFs, 1 BRAM | 590 LUTs, 230 FFs, 49408MEMbits, 122 MHz | 1812 LUTs, 755 FFs, 4 EBRS, 2 SPRAMs, 20.25 Mhz |
Samuel A. Falvo II
Antti Lukats
Michael A. Morris
I'm impressed ! great work !
