Connector selection
A project log for Yaesu - Baofeng/Kenwood converter
Use Baofeng accessories on Yaesu handheld radios and vice versa, includes programming & TNC connection
christoph-tackChristoph Tack 04/19/2020 at 10:230 Comments
Audio jacks
The center to center distance of the audio plugs on the the Yaesu is only 0.3".  So narrow audio jacks must be selected.  Through hole is preferred.  These connectors are likely to be more sturdy and narrower than their SMD counterparts.
2.5mm audio jacks
Digikey selection
SJ1-2503A :5mm wide, center 2.5mm above PCB
3.5mm audio jacks
Digikey selection
STX-3501-3N : 6mm wide, center 2.5mm above PCB
Audio cable assemblies
You should be very carefully about what cable assemblies you buy for this.  The connectors on the Yaesu are very close to each other, you'll never be able to plug in two standard cables.
