Revision R2
A project log for Yaesu - Baofeng/Kenwood converter
Use Baofeng accessories on Yaesu handheld radios and vice versa, includes programming & TNC connection
christoph-tackChristoph Tack 05/29/2021 at 09:550 Comments
Functionality
  1. ✓Microphone input : tested with RSP1A
  2. ✓Speaker : tested by tuning to FM broadcast band
  3. ✓Programming : tested with Chirp
  4. TNC connection :
    1. ✓PC receiving audio : correct volume setting of the radio is crucial.  Use audacity to tune the volume knob to avoid over-steering the laptop's audio input.
    2. ✓PC sending audio : PC volume must be adjusted here as well.
    3. ✓Pulling CN6.5 to GND enables the transmitter
So all functionality works as expected!
