Display:
The matrix is controlled by an ESP32. This was my first ESP32 project and my first foray into ESP-IDF. So I cut some corners and instead of using LCD-Mode, I bitbanged it. With one core fully dedicated to the display and one dedicated to IO I can draw about 3300 monochrome frames per second. Enough for me.
Normally, you redraw the same line a few times (like PWM), to achieve color depth. By only drawing a line once, I trade in color depth for fullscreen refresh rate.
Content:
The Kinect spews out a texture with every pixel color representing the depth. This texture is fed into a HLSL compute-shader which is amazing for this use-case because its so great to parallelize.
The whole thing is then lightly RLC-compressed and send over a raw TCP stream right into the displays framebuffer.
If you could somehow hook this up to use with some of the more popular conference call sorta things that would be really interesting. Keep up the good work!
