PiGFX
A project log for Retro Sargon Chess Computer
This is a retro-computing project whose goal is to put together a platform able to compile and run the original Sargon Z-80 chess code.
davidadkins1davidadkins1 05/24/2020 at 19:070 Comments
4/11/2020
I got the PiGFX ANSI terminal running on the RPi Zero plugged into my #RC2014 Mini. I've run across two versions; pictured is Version 1.1.2 which has better resolution characters. I found I needed to ignore the  PigFX instructions to limit the partition size of the Micro SDHC card. 16 or 32 gig works fine. I also realized a RC2014 reset is required, after PiGFX boots, so that PiGFX will see UART data. Does anyone know how to switch PiGFX from a UK to US Keyboard?
