TDL Macro Assembler
A project log for Retro Sargon Chess Computer
This is a retro-computing project whose goal is to put together a platform able to compile and run the original Sargon Z-80 chess code.
davidadkins1davidadkins1 05/24/2020 at 19:250 Comments
4/12/2020
To compile #Sargon using the original TDL Macro Assembler, I will run an emulation of CP/M using MyZ80 inside DOSBox. Two levels of virtualization! MyZ80 supports import and export of files. Hopefully I can setup a properly memory mapped HEX file for the #RC2014
