4/23/2020
Let me explain. I wondered if it was possible to use the #TRS-80 (#PigFX font 1) graphic characters to build the chess pieces. So I wrote some Z-80 assembly code to print them out (the 'M' is just a separator) through the SCM I/O calls. I printed both white foreground on a black background, and black foreground on a white background:
Then I mapped out the graphic character blocks in a spreadsheet:
I realized they were much like the Jupiter III Wavemate 2x3 graphics. In generating a translation table I discovered the font matched the Sargon black on white chess piece tables exactly. The book, I found, does call them graphic characters. Sometime, somewhere, someone defined these graphic characters and they became an early standard. Good thing, because there is still a problem here...
