-PIC18F46J11 & MCP3424
-works with Pt100 or Pt1000 - automatically recognizes the type of connected sensor
-supports 2 or 4 wire connection of sensors
-temperatures are displayed either separately or as a difference
-USB connection for read
-designed for being powered by a Li-Ion battery, but can be powered solely by USB
-USB connection for reading data, controlling and charging
nice build! I love to see other PIC builds here. I got a few questions for you if you dont mind: what pbc fab house did you use? What Usb stack/compiler?
Also, as a suggestion, you could cut some "smoked" acrylic squares about the same thickness as the enclosure and press fit them over the 7 segments. Makes it much easier to read. I wish i could upload a pic to show you mine on this comment.
