By Popular Demand Size Matters
A project log for RX-Modulus (Completely Modular Mouse)
Finally a mouse that can be freely changed, fixed and upgraded suit the user.
benwbenw 06/27/2020 at 07:400 Comments
As been asked by our great community many questions about this project but the question that comes up the most is the size. So with that said here is the answer.
Note: As the project can change sizes the current full range is:
Length: Min 110mm, Max 140mm
Width: Min 61.4mm, Max 80mm (with larger panel set)
Height: Min 37mm, Max 55mm (with palm rest at max swing)
How does the size of the RX-Modulus compare against other mouses:
I will have to say a big thank you to Raymond Sam from 'thegamingsetup' for producing this very detailed database of gaming mouse sizes (Updated June 8, 2020). If you wish to view this database the link is here: https://thegamingsetup.com/gaming-mouse/buying-guides/mouse-size-chart-table
I've added the size range of the RX-Modulus onto the chart.
As you can see the RX-Modulus size range encompass about 90% of the available mouses on the market, which isn't too bad if you ask me.
So what does this mean?
Well it would certainly see like the old saying "There’s no perfect mouse for everyone, it depends on a bunch of factors, grip type, play style and hand size" Has been overcome with this project as this mouse successfully adapts to all the factors mention. At this time RX-Modulus is suitable for the full range of hands sizes.
As a comparison my hand measures out to 18cm length and 9.5cm width and makes me suitable for medium or large size range of the mouse.
