Added backend server to the UI
A project log for Truly WiFi Extender
A WiFi repeater built around Raspberry Pi under 10 US$ and fully customizable
tejas-lotlikarTejas Lotlikar 07/02/2020 at 17:380 Comments
This webUI is specifically designed to dynamically connect to a WiFi AP using the browser.
Usage
  1. Connect to Access point created by the Raspberry Pi.
  2. Open up a browser and navigate to http://raspberrypi.local:5000
  3. Fill up the SSID and the psk
  4. Click the connect button. Wait for some time(2-3 minutes). Pi will restart itself and now it is good to go!
Dependencies
How to use
You can set the server to auto-start on boot using systemd
