All SCAD files, STL files, program sources, further information and updates can be found on: https://gitlab.com/HardyP/plant-watering-client-wemos_d1_mini .
There you will also find a detailed description of this project in the ReadMe.pdf .
The corresponding plant server is located under https://gitlab.com/HardyP/plant-watering-server-wemos-lolin32
to find.
