In the process of building an IP Camera server. The build so far contains a clear plexiglass housing, an ATX power supply, an 8 port switch, 1 5T USB drive with room for a second, an odroid with motionEye, a raspberry pi with raspbian and node red, an 8x8 RGB Square and cable management.
Details
The short video shows the system in response to motion detection.
Working on finishing up some of the front panel details. Attached 8x8 RGB panel, connected the switch and a little bead board so the front panel can easily be removed by unplugging cables.
There is a DS18B20 sensor that is not currently working with node-red, will be shortly.
The lead screws pull and push holders for the usb hard drives, supports 2 but only 1 is currently being used. Using a screw driver you can push in to disengage the little gears, then turn to clamp the drive into place.
What are the lead screws doing?
