First 3D Design
A project log for berlinClock
Miniature remade of the "Mengenlehreuhr" found in Berlin with part available in my apartment
AlexAlex 05/03/2020 at 00:200 Comments
Most of the Body will be 3D-Printed. In this 3D printed Top 3mm LEDs will be mounted from the back. The red and yellow parts will be printed with transparent filaments. This is a first screen shot from Fusion360:
Later I will add a pole and some kind of base. Inside the Base O will also place most of the Electronics. So far I think I will use a Arduino Nano and a RTC module.
