Welding and Articulation Test
A project log for Autonomous mini-tractor
A small and powerful autonomous tractor.
a-mana man 05/09/2020 at 16:100 Comments
I got the frame welded up and threw on some lawn mower wheels and threaded rod to test the double-articulation. I was afraid it might be too sloppy, but it's actually very solid and should ensure that the mini-tractor has good traction. The turn radius is super tight as well.
I should receive the hoverboard this week.
