My goal with this project is to use readily available components in my parts stash to create a simulacrum of fireflies as you would see them in rural setting. I plan for the circuit to be entirely analog and in the fashion of BEAM robots, I will most likely build these circuits in deadbug fashion with no pcb, perf board or substrate. I plan to weather proof them and place groupings of them in public places like parks or outdoor exercise areas. My goal is to have the circuit be as low power as possible and ideally solar powered with nocturnal operation, I haven't decided if I will use batteries or super-capacitors but either option should be viable.
