U-Blox on USB
A project log for SDR LimeToGo
Remote RX SDR set built to be left outside for radio signal monitoring
djaniDjani 05/19/2020 at 19:180 Comments
Success:
pi@raspberrypi:~ $ lsusb
Bus 001 Device 005: ID 0403:601f Future Technology Devices International, Ltd
Bus 001 Device 004: ID 1546:01a8 U-Blox AG [u-blox 8]
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
pi@raspberrypi:~ $
Soldering is not for beauty contest but I am limited with available R set and old Weller WECP-20 with small tip ;)  bit oversized resistors are on angle to reach the pads.
