BluePillSP0256AL2-schematic.pdf
Schematic of the project (but I'm sure you could have managed already)
Adobe Portable Document Format - 43.17 kB - 05/20/2020 at 17:11
Preview
Download
BluePillSP0256AL2-uart-pa9pa10-20200520a.hex
pre-built firmware; UART version on PA9 (TX) PA10 (RX). By default, expects physical chip to be present, so remember to 'set spmode simulated' if you want that.
hex - 257.47 kB - 05/20/2020 at 15:30
Download
BluePillSP0256AL2-usb-20200520a.hex
pre-built firmware; USB CDC version. By default, expects physical chip to be present, so remember to 'set spmode simulated' if you want that.
hex - 255.83 kB - 05/20/2020 at 15:29
Download
manual.txt
how to connect and use
plain - 5.31 kB - 05/19/2020 at 22:02
Download
testcase_001a.wav
demo ADPCM of doors 'hello'
Waveform Audio File Format (WAV) - 1.38 MB - 05/15/2020 at 23:18
Download
somebodytolove.wav
initial test of text-to-speech algorithm
Waveform Audio File Format (WAV) - 1.07 MB - 05/05/2020 at 15:20
Download
testcase_001.wav
initial test of concatenated phoneme approach
Waveform Audio File Format (WAV) - 1.38 MB - 05/05/2020 at 04:05
Download
