X-Axis
A project log for OpenLRC - The low cost linear rails CNC
Open source CNC project which uses cheap linear rails from china, and aluminum C profiles for modularity and rigidity.
peter-buckleyPeter Buckley 05/22/2020 at 03:420 Comments
The x Axis is the exact same as the regular Spinx. I printed the plates in Black Amazon basics Petg with 5 perimeters and 100% infill.
I used 3d printed rail aligners to temporally install the linear rails. Im using MGN12H knockoffs off alibaba. They are each only held on with 4 screws for now as i am waiting for more to arrive. The lead screws are not installed because i mistakenly ordered them all far to short. Right now i am designing the plates for the y and z axis. And will add nother log when those are complete.
