It works!
A project log for PZ1 6502 laptop
I am building a laptop with a W65C02, lots of memory, SID-sound, decent graphics and a filesystem.
adamklotblixtadam.klotblixt 06/23/2022 at 06:490 Comments
I wrote some low-level tests to make sure the buffers worked properly before implementing the simplest system. A version of EhBasic running in 16KiB ROM (in the Pico) and 48KiB of the external SRAM with one serial port via the Pico USB connection. Runs at a bit faster than 2.5MHz without optimizations or overclocking of the Pico.
I didn't think I'd get it correct on the first try, but the PCB really works as intended, YAY!
I'll wrap it all up neatly and make a decent Github repository of code/PCB/docs before going back to porting Fuzix.
