Finished the PCB
A project log for Small Size 4G Signal Repeater
small size low power 4G signal repeater project, powered with bank powers or 5v USB charger, that can be transferred and moved easily.
abduulah-omranAbduulah Omran 05/12/2020 at 03:370 Comments
Just finished the first version of the Schematics and PCB design .
yet i think the PCB need some review do to many reason , firstly because i lack experience in PCB Deign , secondly is that this is RF PCB, so there is some guidelines to follow.
This PCB is design foe OSHPARK 4 layer pcb .
I followed the common rules of RF PCB designs .
1- Use 50 Ohm Traces ( OSHPARK 4 Layer Stack ) .
2-Curve the RF traces or use slanted corners .
3-4 layer PCB .
some others i didnt follow :
1- I used 0805 SMD components , because it is easier to solder.
2- did not pay attention to the stub pads of smd components on the RF trace. it spouse to increase gradually until it reach the right size
Finally this is a 3D view of the PCB . and i will attach a Schematic and update the Block Diagram.
I can refer any one who is interested in RF PCB to watch Micheal Ossmann YouTube video about RF circuit Design.
