E Paper Display & Microsoft Azure Sphere
Interfacing an 2.9" E-Paper display with Microsoft's Azure Sphere Module using Avnet AzSphere SK
A Library for Interfacing an generic E-Paper display, with SPI Interface, with Microsoft's Azure Sphere Module using Avnet AzSphere SK
Demo Video Link : https://youtu.be/7IiafKY-5VU
ToDo : Add Support for Other Display sizes also.
The project implements a Standard Interface abstraction layer that abstracts the common functions used by each end display into AzSphere_Interface files, and subsequently the main end functions into the respective epd files.
Main Features implemented are as follows
- qrCode generator Library by ricmoo (https://github.com/ricmoo/QRCode) include and tested with 2.9" EPD display by WaveShare
- paint & GFX library by WaveShare interfaced and tested with 2.9" EPD display by WaveShare
- Image Display functionality added
- Sample Images Added
- Supports original LUTs by WaveShare ( Added LUTs from U8G2 Arduino Library but not yet implemented ).
- Supports Partial Mode and refresh.
- Added Horse Running Animation to demonstrate partial mode.
- BareMetal Code, Documented and easy to use.
sch - 110.62 kB - 06/10/2020 at 14:50
Download
Click_SPI_EPD_MOD.brd
Board Layout
brd - 67.62 kB - 06/10/2020 at 14:49
Download
  • 1 × Avnet AzSphere MT3620 SK
  • 1 × 2.9" EPD by WaveShare / Good Display
  • Project Log 3
    Gurinder Singh Gill06/10/2020 at 14:46 0 comments
    For those who prefer something permanent rather than the clumsy Mikro Bus Interface module I had made, I am adding schematic and board design files for the interface module which only would require you to solder the standard headers to make something permanent.
    - Supports Waveshare/GoodDisplay 2.9" Display Module (0.1" Headers pre soldered on the Module)
    - Supports two Waveshare/GoodDisplay 4.2" Display Modules (2mm headers pre soldered on the modules) Provided that Microsoft releases an update to the spi lib for Azure Sphere so that you can define a custom pin as CS pin.
    Regards & Stay Safe
  • Log 2
    Gurinder Singh Gill05/23/2020 at 06:04 0 comments
    NEXT STEPS :-
    Now started working on the 4.2" Display and somehow I managed to blow up my regulator on the AzSphere SK and killed it.
    Will update if anything new happens, meanwhile I will try working on the code part and once I get a new hardware or I somehow fix the existing one I will test it out.
    Will update if any of the above happens .......... ........ ..
  • Log 1
    Gurinder Singh Gill05/23/2020 at 05:59 0 comments
    Finished with the 2.9" EPD and tested the following
    - Basic text and Numerical display using font library by STM
    - Displaying Images
    - Generating QR code with just a text string
    - Basic animations using partial refresh of EPD
    So, I have wrapped everything into a small demo code available on GitHub.
    Thanks for reading :)
View all 3 project logs
