Support for SH1106/SSD1306 based I2C OLED display!
10/11/2020 at 12:35 • 0 commentsYou can now use much cheaper SH1106/SSD1306 display! Just select the display type you use at the beginning of the arduino sketch.
There are a few caveats, though:
1. In order to use SH1106/SSD1306 you will need to add two 470 ohm resistors to the display board.You can add these resistors right on top of 10k resistors that already present (or replace them).
