Modifying the TM1637 Module
A project log for Calorie Restricted Phone Charging
Stop overcharging your phone battery overnight. This puts your lipo batteries on a strict diet by limiting the mAh passing over a USB cable
bornachbornach 05/09/2020 at 17:230 Comments
The TM1637 4-digit module was modified to add 3 buttons and 3 more indicator LEDs
It is easier to solder bodge wires to the pins of the 7-segment LED display instead of the pins of the TM1637 IC.
For more details on modifications to these TM1637 4-digit modules see this video I made a couple years ago
See also this video on the Maxint R&D channel:
