https://github.com/HomeSmartMesh/raspi/blob/master/docker-compose.yml
The dream of mastering IoT software is becoming true thanks to docker-compose.
A single file allows a single command to launch all services
services:
mosquitto:
image: eclipse-mosquitto
ports:
- "1883:1883"
- "1884:1883"
volumes:
- ${PWD}/mosquitto/mosquitto.conf:/mosquitto/config/mosquitto.conf:ro
influx:
image: influxdb
ports:
- "8086:8086"
volumes:
- ${PWD}/influxdb:/var/lib/influxdb
environment:
- INFLUXDB_DB:=mqtt
grafana:
image: grafana/grafana
ports:
- "3000:3000"
network_mode: "host"
volumes:
- ${PWD}/grafana/data:/var/lib/grafana
- ${PWD}/grafana/grafana.ini:/etc/grafana/grafana.ini:ro
depends_on:
- "influx"We see above mosquitto, influx and grafana, but in the full file link above we can also find a custom rf to mqtt service, an mqtt2influx databse script and all sorts of webapps, in addition two instances of zigbee2mqttassistant running each for a separate zigbee2mqtt instance.
Starting a new IoT Home automation project comes down to configuring a single file if not simply using the default config.
Wassim
