Say hello to docker-compose
08/21/2020 at 21:07 • 0 commentshttps://github.com/HomeSmartMesh/raspi/blob/master/docker-compose.yml
The dream of mastering IoT software is becoming true thanks to docker-compose.
A single file allows a single command to launch all services
services: mosquitto: image: eclipse-mosquitto ports: - "1883:1883" - "1884:1883" volumes: - ${PWD}/mosquitto/mosquitto.conf:/mosquitto/config/mosquitto.conf:ro influx: image: influxdb ports: - "8086:8086" volumes: - ${PWD}/influxdb:/var/lib/influxdb environment: - INFLUXDB_DB:=mqtt grafana: image: grafana/grafana ports: - "3000:3000" network_mode: "host" volumes: - ${PWD}/grafana/data:/var/lib/grafana - ${PWD}/grafana/grafana.ini:/etc/grafana/grafana.ini:ro depends_on: - "influx"We see above mosquitto, influx and grafana, but in the full file link above we can also find a custom rf to mqtt service, an mqtt2influx databse script and all sorts of webapps, in addition two instances of zigbee2mqttassistant running each for a separate zigbee2mqtt instance.
Starting a new IoT Home automation project comes down to configuring a single file if not simply using the default config.
Wassim
