Reverse Engineering Motor Signal Board Day 2
A project log for Reviving and Reverse Engineering an Old Robot Arm
A full reverse engineering and rebuild of a Mitsubishi Movemaster robotic arm
taylor-schweizerTaylor Schweizer 05/16/2020 at 21:170 Comments
I'm going through and following the encoder pins for Channel 1. So far I've found that the encoder channels go into a basic transistor switch circuit:
Then it goes into the 74 series logic. This is taking a long time to trace, but here's my progress so far (I have a few more components with various nets off to the side).
Photoshop progress
