Drumming robot
MIDI drum machine to complement live electronic music
Robotic drummer for a concept electronic metal band.
For this project my goal is to learn ::ROS, create parts that look organic by using Generative Design functionality in Autodesk Inventor, get experience with modern servos and linear actuators, and finally build a robotic drummer for my neurometal band. Also see my exoskeleton and cyber guitar.
The files are available on GitHub.
ipt - 1.34 MB - 05/22/2020 at 17:11
Download
ipt - 1.12 MB - 05/22/2020 at 17:11
Download
ipt - 1.02 MB - 05/22/2020 at 17:11
Download
ipt - 215.00 kB - 05/22/2020 at 17:11
Download
ipt - 222.00 kB - 05/22/2020 at 17:11
Download
View all 47 files
  • Finished casting, head re-design
    Valeriy Novytskyy4 days ago 0 comments
    All of the arm parts have been cast, now I need to clean them up/polish them, weld, and send to get them chrome plated.
    After more than a year of struggling to re-create the feeling of my original head concept art, I finally got something I am happy with using a combination of Blender and Inventor. I did the wireframe in Blender starting from the modeling clay sculpt I did in my last update, and adjusting slightly for the concept art and various references from different angles. Then I made it into a solid in Inventor.
  • First half of upper arms cast
    Valeriy Novytskyy06/08/2021 at 05:43 0 comments
    Last week I finished casting the first half of upper arm bones, and this week I am starting on second half. I might be done by the end of June with any luck, assuming I have to re-cast some parts a few times due to mistakes.
    Picture half-way through, with two empty ceramic shells that weren't cast yet, and two metal parts that were cast the day before from identical shells.
  • Casting upper arms
    Valeriy Novytskyy06/03/2021 at 05:25 0 comments
    This week I am casting the first half of upper arm bones. These are split in quarters due to very complex organic geometry (basically they have a hole through them where the pistons go), so that they could be removed from a rubber mold without breaking them. Here are some pictures after first two quarters of wax casts were welded together last November to create a complete half (still in wax, with a wax pen), dipped in slurry and coated in sand. After drying, they were bunt out in a kiln overnight.
  • Face re-design
    Valeriy Novytskyy05/26/2021 at 01:24 0 comments
    Working on face re-design to match my early concept art more closely. Doing it directly in CAD turned out to be too challenging because I would need to have advanced drafting skills to draw the model correctly from multiple views before even starting the CAD program, so I will try sculpting and 3D scanning this time.
  • Finished casting forearms
    Valeriy Novytskyy05/17/2021 at 02:53 0 comments
    Last week I cast remaining forearm pieces in Ctrl^H foundry, and moving onto upper arm parts. Casting is high-priority for this project, so I will go back to cut off sprues, weld the halves together, polish, and chrome after this.
  • Forearm casts almost done
    Valeriy Novytskyy05/06/2021 at 05:43 0 comments
    Past few weeks I cast forearm parts in halves - just need another batch of the other half before I can get started on casting the upper arm.
    I cut off the sprues and started filing the older parts, and also drilled some holes in the oldest part in the right. The quality is decent, but not perfect: it's hard to achieve a completely perfect surface with larger parts. I will likely end up filling imperfections with a metal filler which will create some gray spots and then just chrome all of them. That way they will be metal and chromed, so they will fit with the drum set better.
  • Casting underway
    Valeriy Novytskyy04/29/2021 at 05:10 0 comments
    Preparing more parts for casting this week. Pictured here are new wax positives with sprues added, and a metal copy cast during the last cycle.
  • Encoders Working
    Valeriy Novytskyy04/15/2021 at 20:19 0 comments
    I finally got chained ADS1115 encoders working to read arm bone positions. It was really confusing because the manual lists configuration setting bit offsets in low-endian, but the chip then accepts the resulting bytes in high-endian (reverse) order. Code here:
    https://github.com/01binary/drummingrobot/blob/master/src/code/ads1115.cpp
    The breakthrough came after I took the Raspberry Pi with me hiking and stayed at a countryside hostel for the night, debugging into late hours
  • First casts of the year!
    Valeriy Novytskyy04/15/2021 at 05:52 0 comments
    Last year I completed four-part molds for the robot arms, cast some positives out of wax, sprued them up, and dipped them into slurry to create ceramic shells. This year I steamed wax out of the shells, burned them out in a kiln, and cast the first few parts.
    Like many other large parts I worked on, I am having to cast these in halves so I can weld them later and polish off the welds. The two main limiting factors are my vacuum oven and kiln (each $2000, about the most I could afford) since their inside dimensions cannot fit large parts.
  • Re-working the shoulder
    Valeriy Novytskyy02/01/2021 at 01:52 0 comments
    Last week I made a decision to use a new shoulder motor, so I had to re-design the shoulder to put the motor sideways:
    This week I added source code to read a hollow shaft potentiometer while rotating the motor so that I could stop using an inaccurate metric of PWM "time" to guess the position of the arm, and the performance has been less than acceptable. I already spent two weeks looking for an absolute encoder to read servo positions and this one was the best I could find:
    So now, it looks like I'm forced by build my own encoders. All others are either giant and bulky, or have really difficult legacy programming interface.
    I settled on AS5045, so I will have to design my own board for this chip in Eagle Cad (after I learn Eagle Cad) and manufacture my own housing that's really compact and easy to fit anywhere.
View all 34 project logs
Josh Cole wrote 06/19/2020 at 03:19 point
Hello! This is such a cool project, thank you for sharing your updates. The organic structured prototype parts look sooo amazing. Can't wait to see it all come together.
Valeriy Novytskyy wrote 06/19/2020 at 07:16 point
Thank you Josh!
