Torso planetary gear drive working
A project log for Drumming robot
MIDI drum machine to complement live electronic music
valVal 10/21/2020 at 20:100 Comments
My next goal was learning to control the planetary gear drive with a ClearPath servo hooked up. I got it working this week - using the Velocity Command mode with PWM. The control pinout is Enable, Stop, Velocity, and Velocity Feedback. If you set Enable HIGH, Stop LOW, then PWM Velocity is < 50% duty cycle reverse and >= 50% duty cycle forward. You set the duty cycle constant by connecting that servo to USB and launching a Windows application that configures it. In this case I set 100 Hz as 100% duty cycle, so 50 Hz is half. On Raspberri Pi, I am using pigpio do send PWM with 255 passed for duty cycle to go forward max speed.
