A fridge door alarm circuit using 555 timers senses the status of a fridge door being open OR close. It beeps if the fridge door is left open for too long or hasn’t been closed properly, in order to stop food from spoiling. There are lots of other implied uses to this circuit as well. A refrigerator or freezer door that is left open or ajar may cause the food contents to spoil. So today in this tutorial, I am going to show how to make a simple fridge door alarm circuit using 555 timer IC
Hardware Required
To Buy Cheap Electronic Components Please Visit : UTSOURCE
Solder Base of Both IC’s 555 Timer
Place IC In Base
Solder All Resistors
Solder Capacitors (Ceramic & Electrolytic)
Solder Diode & LED
Solder LDR & Buzzer
Finally Solder Power Connector
Let’s Power up the Circuit
Circuit Diagram
