Pinout for the 30-pin LCD connector
A project log for Hacking a iMac G5 into an HDMI monitor
Resto-modding an old 20" iMac G5 iSight so the LCD can work as an external HDMI monitor for a laptop.
thomasThomas 05/15/2020 at 06:390 Comments
Not sure why, but tracking down a datasheet or service manual for the LG-Phillips LM201S01(ST)(B2) LCD monitor has been much more challenging than I would have thought (the datasheet appears to be available for download from this site, but there's a complex paywall that I lost patience with). After a week of searching, I pulled the following image off a Russian forum, and it claims to be the official pinout for the 30-pin monitor connector for our monitor:
This pinout matches most of the other data I have, except for one major inconsistency: this pinout indicates that VCC for the monitor is 12V power, while the labeling on the actual connector (the small connector opposite the 30-pin LCD connector) clearly says 3.3V.
So is VCC for the monitor 3.3V or 12V?
