Useful suggestion
A project log for Amplifer 60->100W
60W -> 100W Texas Power Amplifier for home SUB boxes
Kerekes ZsomborKerekes Zsombor 05/14/2020 at 15:010 Comments
From the input through the volume cutter to the desired tone control from there to the output. Use a shielded wire between each. Exception is thick power and speaker wires.
