Overview
Twelvey provides a compact control voltage interface for one “octave” of musical notes. Twelve voltage divider circuits send distinct voltages through a common output port.
Technical Details
This device contains twelve parallel voltage divider circuits, each providing between +5V and +6V of “control voltage” for a CV-based sound synthesizer. By adding “keys” (e.g., momentary button switches), this circuit will approximate the 1V/Oct implementation common on several analog synthesizer platforms, as follows:
Keys
Input Voltage (V)
Output Voltage (V)
1
9
5.00
2
9
5.09
3
9
5.18
4
9
5.27
5
9
5.36
6
9
5.45
7
9
5.55
8
9
5.64
9
9
5.73
10
9
5.82
11
9
5.91
12
9
6.00
Audio output may or may not equate to a true musical “octave;” this device can be connected to any number of possible synthesizers under any number of possible conditions. The output should, however, constitute twelve distinct voltages, increasing regularly from lowest to highest, which may approximate an octave-like scale.
Rating
Designator
Footprint
LCSC Part Number
40V 3A 550mV @ 3A Schottky Barrier Diodes
D1, D2, D3, D4, D5, D6, D7, D8, D9, D10, D11, D12
SOD-123FL
C142342
1KΩ Resistor
R1, R2, R3, R4, R5, R6, R7, R8, R9, R10, R11, R12, R13, R15, R16, R17, R18, R19, R20, R21, R22, R23, R24, R25
R0603
C118155
1.2KΩ Resistor
R14
R0805
C269531
220Ω Resistor
R26
R0603
C203410
100Ω Resistor
R27
R0603
C269683
330Ω Resistor
R28, R29
R0603
C325681
470Ω Resistor
R30, R31
R0402
C325387
560Ω Resistor
R32
R0603
C325729
680Ω Resistor
R33, R34
R0603
C325626
820Ω Resistor
R35, R36
R0603
C325631
30Ω Resistor
R37, R40
R0805
C325808
5.1Ω Resistor
R38
R0805
C325852
9.1Ω Resistor
R39
R0805
C245438
82Ω Resistor
R41, R45
R0805
C325829
68Ω Resistor
R42, R44
R0603
C325751
47Ω Resistor
R43
R1206
C325924
General Usage
To use this device as a CV controller, connect the following:
  1. A power supply
  2. Buttons or switches
  3. An output jack
Additional Options
This design features a space (currently unused) for a built-in dual oscillator based on Texas Instruments’ Dual 2-Input NAND Gate With Schmitt-Trigger Inputs (SN74LVC2G132). Certain locations on the PCB (Ports 1-7, 3G, 7G, and IC SW) are designed to work with this planned feature.
